0 Members and 1 Guest are viewing this topic. Read 17865 times.
The Minis are 87dB @ 1W/1M sensitivity each. If you sit 3 meters away then one watt will produce an SPL of 75dB at your listening position. To play at a relatively modest level of 85dB at the seating position you will then need 10 watts per channel. Then suppose a 10dB peak comes along. Now you need 100 watts to keep from clipping. But... what if it's a 13dB peak? Now you need 200 watts to keep from clipping. The NuForces don't have that much output into 8-ohms and I'll bet they won't even reach their spec with a full 500mS burst. Add to that, peaks as high as 20dB can occur on many of your better audiophile recordings. Were you amp asked to reproduce one of those you'd need 1,000 watts!
Of course one further advantage is that with a pair of Ultra 550 amplifiers, you have over a kilowatt of power available per channel.
Quote from: SP Pres on 24 Jul 2008, 05:30 pmLooks like Frank will be selling more of his AVA Differential systems.Quote from: avahifiOf course one further advantage is that with a pair of Ultra 550 amplifiers, you have over a kilowatt of power available per channel. What is that AVA Differential system and how do I learn more?Is that 2 Ultra mono stereo , 2 total or 4?
An "issue" with SP Tech speakers which a reviewer warned me about is that it's waaaaaaaay too easy to listen at a much higher volume than you might think. Their super low distortion sort of hides (to me) the normal volume cues, so be careful. Purchasing a inexpensive (but relatively accurate) SPL meter may help preserve your hearing.
Ok, I've had the Minis just over 48 hours and everything you guys have said about them is true.
I was not prepared for the quality and quantity of bass these diminutive beauties produce. Kick drum astounded me with the tightness and depth of tone. Unbelievable! The only things I lost without the sub was the sense of space one gets with very good recordings of orchestras in great acoustically reverberant concert halls, synthesizer, and large organ pieces. More to come. aa
My solution is to listen at 80db max, meaning I can get away with 100W easily - maybe even 50W.
They sound good at low volumes, too, but they really spring to life as you turn the volume knob clockwise.
