0 Members and 1 Guest are viewing this topic. Read 26581 times.
Q: How do you feel about the new generation of Class-D amplification?A: "Class D amplifiers have been around since the beginning of time, and every year I thought that they were finally going to come of age. I tried making a Class D amplifier twenty years ago and failed miserably. I couldn't make it sound good, and so I gave up. They've always seemed to be on the threshold of fulfilling their promise, which is high power, great fidelity, lightweight, and no heat, but it hasn’t happened yet. They have a fundamental problem-they don't sound good. They haven't come of age yet, but every time I turn around there's a new one that makes the promise that switching technology has arrived. It’s the linear guys who are carrying the day. Theoretically, switching amps should be good, but they’re not yet. And there’s some technical reason for that, and I could explain it but I don’t need to now unless you want me to.“
I purchased a Spectron Musician III SE (recently upgraded to Mk2)
The following is not for shock value, but only to share one highly experienced person's opinion.TAS, August '08, Issue 183, page 33, Bob Carver interview (Physics PhD. Carver may have more patents currently licensed & in use than all other living high-end inventors combined).
Quote from: ro7939 on 30 Jul 2008, 04:03 pmThe following is not for shock value, but only to share one highly experienced person's opinion.TAS, August '08, Issue 183, page 33, Bob Carver interview (Physics PhD. Carver may have more patents currently licensed & in use than all other living high-end inventors combined). With all of his expertise, what "reference" gear has Mr Carver contributed to the industry in all his years?
This guy sounds like he's bitter that people are enjoying Class D amps that he didn't design. His Ph.D and design experience doesn't relate to how I perceive music so his opinion is about as important to me as anybody else's.
this guy sounds like he's bitter
I like the fact that the Class D amps are a green solution.
In terms of power supplies, a good SMPS seems to be as good as the transformer/rectifier/caps solution. The SMPS actually has better regulation but it doesn't seem to matter as the PSRR of the Hypex units is very good and I have found very little audible difference between the two. Switching noise can be handled in the design.
Quote from: Kevin Haskins on 30 Jul 2008, 04:42 pmI like the fact that the Class D amps are a green solution. This intrigues me, and I have a follow-on question based on what Kevin says next:Quote from: Kevin Haskins on 30 Jul 2008, 04:42 pm In terms of power supplies, a good SMPS seems to be as good as the transformer/rectifier/caps solution. The SMPS actually has better regulation but it doesn't seem to matter as the PSRR of the Hypex units is very good and I have found very little audible difference between the two. Switching noise can be handled in the design. Is there any difference in "greenness" between a switching power supply and a linear supply? Certainly a SMPS will be smaller and lighter than the equivalent transformer-based power supply, but is there a substantial difference in energy efficiency? -Rob
If Bob states he thinks D does not sound good & he has electrical data to back it up, that's all it is. Bob's probably worth more than just about every other designer combined. He very used to personal attacks & admits his youthful failures in his earlier audio attacks in the same interview.
The high-end contradictions still amaze me. People like Carver & Dan Banquer swear D doesn't work, others who seem just as reliable in their opinions swear they do. Who knows? [...]
The THD numbers may be slightly worse than a good Class A/B design but I don't think anyone gives much weight to a simple THD number correlating to sound quality anymore.
