Should I get a slider wall to cut off that 10x12 space while listening to music?
Nuance,Where would you get a slider wall? I have the same configuration in my room, and was looking at the office cubicle wall things.
QuoteShould I get a slider wall to cut off that 10x12 space while listening to music?I am not an expert, but I would think that the opening would be similar to an absorption panel. So, if your room permits, then buying an absorption panel and putting on the opposite wall might be a better solution.Bob
That's certainly an option. You think that would be the better route then?
