D-100 Voltage Change
naggots
« on: 18 Jul 2008, 08:29 am »
Hi Dusty, will a pair of D-100's purchased in the US at 110v be converted to 240v as the VDA2/VAC1 combo did.Thanks, George
denjo
Re: D-100 Voltage Change
« Reply #1 on: 18 Jul 2008, 10:34 am »
George
I asked Dusty the selfsame question before when I had the D*200s and he advised that it can be done but you will need some soldering skills and a set of instructions from him. I believe it will involve more than jumper changes.
Hope this helps!
Best Regards
Dennis
CIAudio
« Reply #2 on: 18 Jul 2008, 03:15 pm »
Yes, input voltage is set by solder-in jumpers (similar to VAC-1).
No other changes are required.
naggots
« Reply #3 on: 19 Jul 2008, 01:10 am »
Thanks..... :D
