Marchand xm126 xover advice or DEQX system
0 Members and 1 Guest are viewing this topic. Read 1142 times.
tweaker 155
« on: 10 Jul 2008, 12:32 pm »
Hello guys,
Can anyone help me choosing the better system .
What are the pros and cons of using either one.
Which way is the best possible sound out of multiple amps say 4  way ,8 channel system
Has anyone modified the XM 126 units
Cheers
sbrtoy
Re: Marchand xm126 xover advice or DEQX system
« Reply #1 on: 10 Jul 2008, 01:53 pm »
I would search around on the subject here and on other forums, these are two very different animals.  The Marchand is analog and the Deqx is digital, both have pros and cons but it really comes down to what you are trying to achieve and what your system is.
woodsyi
« Reply #2 on: 10 Jul 2008, 02:13 pm »
Marchand won't to any fancy 8 channel stuff -- only 2.  I don't know if DEQX will do multichannel DSP.
