Help with damaged 938
0 Members and 1 Guest are viewing this topic. Read 3810 times.
Ofseng
« on: 8 Jul 2008, 03:42 pm »
Hi all
New to circle, I have owned my 938's for a while but have recently damaged the Piano black finish. Does anyone know what type of paint and lacquer Hyperion use? I need to get these repaired locally as I am in UK.
laserman
  • Ambiguous-Optimist
Re: Help with damaged 938
« Reply #1 on: 9 Jul 2008, 06:43 pm »
Ofseng,
I would recommend going to a piano restorer and let them fix it.  Check with your local piano stores to get a recommendation on who to take it to.  They will know what to do and generally will be reasonable in cost.
Good luck,
L
