0 Members and 1 Guest are viewing this topic. Read 3548 times.
OK, this project was by far the most ambitious. Dillan used 9 Madisound Foster 5 1/2" drivers in what was to be an open baffle line array. He decided to make it a variation on a 3 way with 5 drivers doing bass duty, and 4 doing midrange duty. The tweeter was the GR-Research T-6 dome with a 96 dB sensitivity. Quickly, he ran into phase problems and worked and worked to tame them as best he could. The adjustable wings on the baffle surprisingly had little affect on the FR curves. Although fast and articulate, it still needs crossover work and probably a subwoofer. High marks to him for attempting a project that was waaaayyyy beyond the requirements.In addition to an ambitious project, it looked really good! The cloth cover has adjustable baffle extensions attached with piano hinges.And the FR curve...
Interesting stuff - thanks for sharing. Looks like some pretty ambitious projects. Is it just me or does Adam's curve look like the xover point is showing a problem with phase? Bryan
Quote from: bpape on 8 Jul 2008, 03:23 amInteresting stuff - thanks for sharing. Looks like some pretty ambitious projects. Is it just me or does Adam's curve look like the xover point is showing a problem with phase? BryanWell, it does look like a phase problem, but reversing the tweeter did not improve things. Adam was the only kid working on the project without a physics background. Being from a different school, he jumped on the project just because he wanted to. I met with him several times to offer suggestions, but in the end he went in his own direction. My suggestion was to go with a MTM instead of an MMTMM.
Quote from: S Clark on 7 Jul 2008, 11:30 pmOK, this project was by far the most ambitious. Dillan used 9 Madisound Foster 5 1/2" drivers in what was to be an open baffle line array. And the originalFR curve...
