DIY Subwoofers
0 Members and 1 Guest are viewing this topic. Read 4155 times.
Sonny
Re: DIY Subwoofers
« Reply #21 on: 6 Aug 2008, 11:30 pm »
Thanks Haoleb,
I wonder if there is a CAD of this...Also, I am looking for a sealed design....
Tuan
Haoleb
Re: DIY Subwoofers
« Reply #22 on: 7 Aug 2008, 01:10 am »
There are CAD drawings of the subwoofer in the first link, if that is what you were reffering to. If you're looking for a sealed design for sound quality, I think you'll be very impressed with this design, Also if you use the DCX2496 with it you can make it sound like a sealed sub with simply adding in a filter, if you felt it did not sound "tight" enough.  I believe the quality and flexibilty of the components and the overall design is far beyond that of the majority of the subwoofers available. at any price.
