0 Members and 1 Guest are viewing this topic. Read 15770 times.
Here is a summary of my noise problem. Using two CineNova 3 ch amps, the Kenwood VR-6070, Denon DVD-2900, Cable Box I have loud buzz or hiss or hum on my VMPS RM2. and center.I have tried many remedies and none have worked. Like dedicated line, Rat Shack filters, unplugging everything.I disconnected the RCA cables from the amp,(no other component connected, dvd, cable box all diconnected) and with the amps on and speaker wire connected between amps and speaker there is a very, very slight, what I woul ...
I've got the same 2 units as Byteme. I think it was his review that inspired me. In any case, they look old, they buzz, but, they do lower the noise a little. I haven't upgraded the outlet or done any other work but, I'm not happy about the constant buzz from the transformers. So, I'm not sure what I'm going to do with them. Can the transformers be replaced with a toroidal? Also, I initially thought they were removing some FM radio that's been coming through my system. Unfortunately, I still get ' ...
Carlman, I've had trouble with one getting "buzzy" since my review. I've tried to replace it but the one I bought was not quieter, so the search continues. I've found that it pays to specify before purchase that you're using it for audio and the transformer needs to be totally silent. In my case even that didn't help. So, you do have to be careful, but for $30-50 it's still hard to go wrong. The two 1102's I have are still silent and working wonders just as indicated in my original review.
Hi MaxCastNo other pre amp at present but that would be an interesting experiment. On the other hand the noise is still there without the Kenwood and just the amps. Or without the amps and just the Kenwood.
