0 Members and 1 Guest are viewing this topic. Read 8396 times.
Stop over tomorrow if you want. A couple others will be here around 5'ish
Oh well - guess it'll have to be next week sometime then... Bryan
I've been following this and am curious about the front baffle. Will there be a solid baffle attached on the front? Meaning between the points on each side or will the drivers mount directly on the frame as it sits now? Thanks.
There will be a baffle, and the cab as you see it will be cutout for drivers. The space for the baffle is 1 1/8" thick, just right for a constrained layer baffle of 1/2" baltic birch, 1/2" MDF, and 1/8" mass loaded vinyl inbetween.
But it doesn't look big enough to hold a fifteen. You know....a MAN sized driver.
