0 Members and 1 Guest are viewing this topic. Read 4943 times.
Wow Ed!That's about the most perfect answer to the question I've ever seen. Well done. Tony. Just read what Ed said. It's all there.
Yes, active bass is the way to go for OB. Unless you have big baffles and multiple drivers.But here's the funny thing; Even tho I'm currently running plate amps on my OB 15s, the bass is different with different main amps. Yes, the signal is running speaker level to the plate amps, but the plate amps "should" be doing the grunt work, not the main amp.Despite that, the difference in bass response and feel is noticeable between different amps. Guess it's time to try line level into the plate amps.FWIW, all of the biggest, best systems I heard in Europe used SS amps for the low end. SET was reserved for mid and treble duty - only.
Assuming you are talking about using speaker level inputs for the plate amp, the plate amp will have a variable Xover, and volume, and phase so you can adjust it one time to suit a balance between main driver and helper woofer, and as you raise and lower the volume on the main amp, so too with the bass driver follow.
I use an AV processor to split the signal, sub out to subwoofer, line to tube amplifier,
Quote from: lowrider on 28 Jun 2008, 08:14 amI use an AV processor to split the signal, sub out to subwoofer, line to tube amplifier, Interesting approach. On the processor do you set the main speakers to "small" to limit the bass going to them?
Completing the bass picture is easy with one order from Parts Express as far as I am concerned. Seems the Eminence Alpha 15 is the budget champion, with specs that are ideal for OB and come with Martin King's seal of approval. For the bass, it seems many people are getting away using the active level XO on sub plate amps, and letting the mains driver roll off acoustically, which begins ~400Hz anyway. In truth, in my experience and that of others, it is pretty hard to fail. I am of the opinion that it is a waste of tube juice, powering big cones with nice flea amps.DMasonI am taken by your argument to indulge myself with the TT 10" alnico+ SET . However in my limited listening room 15' x !0' with speakers firing down the length of the room I am a bit concerned that a 15" bass driver may overwhelm the room. Do you think that a smaller driver may be more siutable, secondly is a tweeter needed to fill in the gaps above the top end of the TT 10".
I say indulge in the TT10's, slap them onto a baffle, get used to them, Erling shows they model fantastically well, and decide about a bass driver later. Michael's idea about the Dayton is gold, Erling's idea about a "topless" U baffle is a proven variation on a theme, and personally, with some contouring, to jack up the treble reach, I found I got very used to just the Tubby 10, as it was.These drivers with SET amps are just stunning. They sound sooo good on their own with prerecorded music that you will be more than happy to enjoy them on their own, while figuring out how to optimize the whole thing to your room and taste. www.svvintageamps.com Scott is your man.
