0 Members and 1 Guest are viewing this topic. Read 6648 times.
Yea, those look like loads of fun. Fast enough to be a blast, but not fast enough to be "scary fast".John, on the other side of Missouri from St. Louis (few hundered miles) is a SAAB dealership in Kansas City called "George's Imports". They are not just a new/used car dealership, they're also heavy into racing. Customers can even have their SAAB 'tweeked' to whatever extent their wallet can handle. I've had some of my customers ask me why my dealship doesn't do the same. A few of them have taken their SAAB's to George's for performance upgrades. A fellow last week claims just over 400HP from tuning plus extensive suspension mods. Can't remember why he was in my place for service, but when I looked at the car is was a $50 POS at best. Probably fun as Hell to drive, but it had a lot of problems.Here's George's: http://www.kcsaab.com/index.aspClick "Racing" to see the cars the dealership races.Bob
A H brace under the front should solve all understeer woes (in the wrx specifically but probably any car) or a sway.People often get it backwards thinking a stiffer front end will result in more understeer but that is not the case, in a car that is generally disposed to understeer you want to put relatively more stiffness into the front to balance it. (it keeps the front tires more level during cornering thus maintaining maximum grip levels)In fact, re reading what you have done regarding tyre pressure, if you were dropping the rear pressure from ideal back until the car was better balanced then id say you've done it by reducing grip levels at the rear until it was balanced with that of the front... ie not the ideal way to do it. Since you've got a rear sway on that is thicker than stock you probably made your understeer worse at that point as the rear tyres will remain flat cornering up to a higher speed than before and the fronts wont.
(Bob - cool input - you really do or did represent the bastards and rejects of the US auto scene there...no Yugo or Triumph ever at that dealership? How'd they miss those? )
if you were dropping the rear pressure from ideal back until the car was better balanced then id say you've done it by reducing grip levels at the rear untill it was balanced with that of the front... ie not the ideal way to do it.
Hi Chair guy, I have been missing for a few years because i was focusing on my business and not audio... also my stereo is really well sorted now and I don't feel the need to tweak it anymore.also a got the wrx so i was tweaking that (which im finished with too so now its back to audio tweaking)In any case there is tons of variables with cars that I can only recommend you take it to a renowned suspension development shop in your area and get them to look at what needs doing. One of the best mods i ever did to the wrx was get it properly tweeked at Wheels World. (and cheapest)
