0 Members and 1 Guest are viewing this topic. Read 9048 times.
Buying insects is the easiest way to get edible insects, but it is also the most expensive (ain't it always the way?). Most pet stores and bait shops carry crickets and mealworms, two of the most easily raised and prepared insect species. You can also buy these insects in bulk from various insect suppliers. The only preparation that you need give to insects acquired in this manner is that of feeding them for a few days on fresh grain; most insects you buy at bait shops or pet stores have been eating newspaper, sawdust, or similarly unsavory packing material, which, while completely harmless, might affect the insect's taste if you ate them while the material was still in their digestive tract.
To prepare a batch of crickets or mealworms:Take the desired quantity of live insects, rinse them off and then pat them dry. This procedure is easy to do with mealworms, but fairly hard to do with crickets. To do so with crickets, pour them all into a colander and cover it quickly with a piece of wire screening or cheesecloth. Rinse them, then dry them by shaking the colander until all the water drains. Then put the crickets or mealworms in a plastic bag and put them in the freezer until they are dead but not frozen. Fifteen minutes or so should be sufficient. Then take them out and rinse them again. You don't really have to clean mealworms, though if you want, you can chop off their heads. Cricket's heads, hind legs, and wing cases can be removed according to personal preference; I like doing so, since cricket legs tend to get stuck in your teeth. You are now ready to use the insects in all kinds of culinary treats!
Chocolate Covered Crickets * 25 adult crickets Several squares of semisweet chocolatePrepare the crickets as described above. Bake at 250 degrees until crunchy (the time needed varies from oven to oven). Heat the squares of semi sweet chocolate in a double boiler until melted. Dip the dry roasted crickets in the melted chocolate one by one, and then set the chocolate covered crickets out to dry on a piece of wax paper. Enjoy! This is a little time consuming to make, but definitely worth it...the crickets are deliciously crunchy!
Anyone ever try crickets? They are supposed to be very nutritious. What do they taste like and what are some of the ways to prepare them? Open mind but closed mouth for now. Just cricket curious.
I would think crickets would be a an audio pet peeve. Noisy little critters in the summer time.
I would think crickets would be an audio pet peeve. Noisy little critters in the summer time. And how do they keep up all that racket with out wearing out their back legs.Eating them makes me sick. Like the Indiana Jones #2 movie where they eat those big beatles, snakes and stuff barf!
I ate deep fried crickets in Taiwan, they were actually quite good!
