Torus question for James
splittailz
« on: 18 Jun 2008, 05:00 pm »
hello James, I was wondering if there is any reason to turn off the Torus's when not in use?
As in, if I am just watching TV, and the TV is connected to 1 20 amp leg of my RM60, should I turn off the other 2 switches/circuit breakers that control the amps and subs?
the power draw from the wall should be in relation to what is being used by connected equiptment correct?
thanks
  • The Demo is Everything!
    • http://www.bryston.com
Re: Torus question for James
« Reply #1 on: 18 Jun 2008, 05:09 pm »
thanks
Hi split,
Yes just leave it on.
james
