Do Nuforce products sound better with their tops off?
0 Members and 1 Guest are viewing this topic. Read 2370 times.
Arnoldhasmail
I've often found that preamps and power amps sound better without the unit tops on...I'm wondering if that's true with the Nuforce products?  Is it a problem to run the amps open?
Any input Jason?  I don't have pets or kids so I'm not concerned with anyone getting inside or getting shocked...I'm only interested in damage to the units...and sound quality...
Will RF interference increase?
Thanks in advance
rustydoglim
    • www.nuprimeaudio.com
Re: Do Nuforce products sound better with their tops off?
« Reply #1 on: 18 Jun 2008, 11:21 pm »
No, you can't do that and it won't sound good either. The top cover is used as heatsink and provide RFI shielding.
Arnoldhasmail
« Reply #2 on: 19 Jun 2008, 12:10 am »
Thanks...appreciate the quick response
toocool4
« Reply #3 on: 7 Aug 2008, 09:19 pm »
I use HRS damping plates on top of my 9 SE V2’s, they are a cheap upgrade for the improvement they make. Check it out here www.avisolation.com/damping_plate.html
Chris
Sonny
« Reply #4 on: 7 Aug 2008, 09:43 pm »
Thanks in advance
Don't know, but if she's hot...well, that only makes it better! :nono:
