0 Members and 1 Guest are viewing this topic. Read 11946 times.
Are you watching the bias closely during break in, and setting it anew when swapping brands? Sounds like too much bias current burning them out prematurely, the behavior is typical of a worn out tube. Typical bias on KT88 is 75ma, how much bias are you putting to them? You could email Jim McShane, he sells them and might have additional insight. jimmcshane -at- prodigy.netFrom Jim's website:"Genalex Gold Lion KT-88 reissues - good stock on hand! The listening reports are virtually unanimous, regardless of what gear the tubes go in. This tube is clearly the equal of and according to many may even be better than the original GEC. It is absolutely the best on the market now! My impressions from handling and matching the tubes are extremely positive. The tube is very substantial in your hand, they feel heavy and look well made. Pin soldering is excellent! There have been just a small handful of the nearly 800 tubes I've sold that have had any issues at all."
Yup, makes sense. But despite the lack of a logical answer to satisfy the intellect, the symptoms suggest over-driving the tubes. So maybe try running them at 50ma or even lower and see what happens. Maybe start at 30ma and add 5ma at a time until you hit the point of dimishing returns, trying to find the lowest bias point at which it still sounds great. You will have to do it over time to allow the brain to adjust, because higher bias will usually sound "better" in A/B. Verify the resistors for setting bias are correct, etc. Maybe you have inacurate bias gaging, and the other brands just tolerate overdriving better. Good luck freo
Can you provide more details on your amps? What brand are they? Do you have a copy of the schematic?The behavior you're seeing would be consistent with the Gold Lions having a bit more grid current than the other 6550 tubes. If your amps use a large value grid resistor then they could start running away. Dropping the value of the output tube grid resistors and perhaps increasing the coupling caps to keep the same low frequency roll off would be the cure. But that would require some soldering to see if it helps.---Gary
I know the Citation II very well - I have one. I totally rebuilt it with new diodes and power supply caps from Jim McShane, redid the bias supply, and replaced most of the caps and resistors plus a few other mods. I've got the output tubes wired in triode mode but haven't changed the input or driver tubes.If your tech replaced the bias resistors, it would be good to check that he didn't change the value. If he used a smaller resistor then you might be biasing the tubes hotter than you think.It's also possible that when your output tubes started running away, they took out or least made the grid resistors go out of spec a bit. The grid resistors are supposed to be 100K (R24 and R31) so you should check to see if they're still in spec.Good luck.---Gary
Just curious, are you using the GL Re-Issues?
Quote from: Freo-1 on 15 Jun 2008, 12:38 pmJust curious, are you using the GL Re-Issues? Nope - I'm running some of the Ei KT-90 tubes. Unfortunately these are no longer available, but I've got a back up NOS quad for whenever my current set bites the dust. According to Jim McShane, who I trust, the GL KT-88 reissues are the best tubes available for the Citation II right now. So I believe that there is some quirk in your amp that you need to track down. Or just enjoy the GE 6550s which don't give you any problems. They're supposed to be good tubes.---Gary
. . . Kevin Deal (who I also trust) would not sell me KT-90s when he still had them for the Cit II, as he said that "they will blow up your amp".
The other thing to try is put the older KT88s in, say your Svet (or JJs) KT88s and see if they work out ok.
Were the GL KT88s you had tried all bought together at the same time (thus implying they might have been from same lot)? Or did you buy some at one point and some later?
Reports I've read said that the GL's were really reliable tubes. But sometimes you get a bad lot, it can happen. However, it seems like you might be rushing to conclusion. One doesn't really need to see a spec sheet on a tube, but they are provided by some manufacturers. These just provide a suggested operating point, usually the one most commonly noted in tube manuals, etc. But a KT88 is a KT88 and by definition is intended to be o
