14BSST vs 14BSST Professional
smerlas
« on: 14 Jun 2008, 02:01 am »
I have reviewed the Bryston Website and am unsure of the difference between the 14BSST and the professional series, can someone shed some light?   :scratch:
The one difference that I was able to determine is the ability to get the 14BSST pro in a 240v configuration, any others?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 14BSST vs 14BSST Professional
« Reply #1 on: 14 Jun 2008, 02:28 am »
The  Pro series is available in Black 19 inch rack mount faceplate only.
http://bryston.ca/14bsstpro_m.html
The consumer C- Series is available with the C-Series cosmetics - in silver or black and in 19 inch faceplate or 17 inch faceplate.
http://bryston.ca/14bsst_m.html
The Pro series also has volume controls in the circuit path on each channel - the consumer C-Series does not.
I usually recommend the C-Series if you want the simplest cleanest signal path and the Pro if you need the volume control on each channel.
Both Consumer and Pro are available in 240 Volt.
james
