0 Members and 1 Guest are viewing this topic. Read 6852 times.
spend some money here and look at the Marantz AV line, Onko Line, Parrsound, or look for seperates. Stay away from Sony, HK, Pioneer, etc. 2) As for speakers given that your room is not as big as a movie theater a center channel is a waste of money
My 50" GWIII LCD RPTV is pretty high, so if the center channel was placed on top, it would be almost 1.5' above my head. Is this a problem? Does teh center channel need to be head level?...
You can easily have your center higher than head level. Just aim it down a bit so that the tweeter is aimed at ear level.M&K makes brackets to angle their speakers down that work great. I'm using one on my S-125C, and my Surround 550-THX rear centers. The friend of mine with the K7's has one on his center channel as well.
