0 Members and 1 Guest are viewing this topic. Read 11502 times.
From Rick Schultz at Virtual Dynamics http://www.virtualdynamics.ca/the-oddiophile-eps--1/
Did y'all make sure all of your original screws were well tightened before replacing them? After receiving my new speakers (not Omegas) I was surprised at how many needed tightening. I got improvement without changing them, just tightening.
For those of you who wish to torque your brass screws, the link below identifies the torque screwdriver I purchased. The problem with the gunsmithing tool identified by Virtual Dynamics is the scale begins at 5 inch pounds which can either snap or destroy the head of a #6 or #8 slotted solid brass wood screw. The woodworking tool below goes down to 2 inch pounds. Start there and work your way up. http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=7689
You are welcome. They are handy gadgets just as you've said and the price is great. The commercial, high grade, precision versions of these can cost up to $300. I wonder if George has already ordered one aa I mean the $35 model, of course
