Looks great VL!What are you using for marinade?Hibuck...
Vinyl Lady, that looks amazing!I almost bought a Traeger.....that's a lifetime unit right there!
I did just that. And when I took it out of the cooler I had to use a circular saw to cut it.
And inexpensive too.
I’ve smoked meats in different grills and semi-smokers (brinkman) but never a true smoker until now.The best luck I’ve had with charcoal and gas grills was to have one side set at the lowest heatsetting and put the meat on the other side, get a big sheet of aluminum foil put some wet hickory chips in it and wrap it up in a ball poke some holes in it and put it on the heat side of the grill, 4 or so hours later you got some good smoked meat.But now since I picked up a Masterbuilt smoker I have great smoked meat with unbelievable tasteand very moist, some of the best ribs I have ever eaten. Masterbuilt Link
Smoke Salmon is spectacular!
That's what my wife asked for for mothers day, so I went to the boat docks and bought a huge whole salmon Saturday morning and some clams. Grilled the clams and smoked a large piece of the salmon. Yummy!As for that Master Built smoker, I owned it for a while but the electronics crapped out after about 2 years. I kept it going another year by basically rebuilding them, but eventually gave up the ghost. I now have a propane gas fired smoker which is very simple and works like a charm.
