TVC or DAC
0 Members and 1 Guest are viewing this topic. Read 3157 times.
sskong
TVC or DAC
« on: 7 Jun 2008, 12:41 pm »
Hi,
I'm planning to upgrade my current system that consists of the following :-
CD - Marantz CD63SE
Amp - Consonance M100-06 (EL34)
Speaker - Mission 772
Should I go for TVC or DAC ? Heard that the DAC give a tubey sound. Is that true ?
tanchiro58
Re: TVC or DAC
« Reply #1 on: 7 Jun 2008, 01:19 pm »
Hi,
CD - Marantz CD63SE
Yes, it is true. If you can tweak around with Promitheus DAC it sounds even much better.
If you can afford the TVC Reference C-core you should go for it. Both TVC and DAC (even with the new tube DAC from Nicholas) are an excellent combination in your system.
Good luck,
Tan
sskong
Re: TVC or DAC
« Reply #2 on: 7 Jun 2008, 01:31 pm »
Hi Tan,
Is only to choose ONE, which one you advise ? DAC or TVC ? If DAC that provide tubey sound, would it mess up the current sound as I'm already using tube amp ? FYI, my CD63SE is modified player.
Any idea on the payment ? COD or pay first then deliver ? Understand that need to wait for a long period.
kong
Early B.
Re: TVC or DAC
« Reply #3 on: 7 Jun 2008, 09:12 pm »
Get the TVC.
Brown
Re: TVC or DAC
« Reply #4 on: 7 Jun 2008, 11:47 pm »
Is your amp an intergrated one. Only becauce you did not mention the existing preamp. If you have a power amp only buy the TVC.
sskong
Re: TVC or DAC
« Reply #5 on: 8 Jun 2008, 08:21 am »
My amp is an integrated amp. TVC not suitable ?
Early B.
Re: TVC or DAC
« Reply #6 on: 8 Jun 2008, 11:21 pm »
A TVC is certainly suitable. Place it between your CDP and int. amp.
TVC or DAC -- either way it's a win-win for you.
