I've probably asked this before, but where is the best bang for your buck with PC's? My thinking was the preamp, amp, and then maybe the DAC in that order. I usually worry less about a Squeezebox power supply item.I have a Lessloss on the pre and a nice Moon Silver Dragon on the Pass Lab and the original Iego's silver platedon the other stuff with a few Signal Cable PCs thrown in. Not sure where to apply one, but was interested in the gold version C for more body. But needing almost 3 meters for the amp attempt and only 1 to 2 meters for the pre.....
Quote from: Big Red Machine on 6 Jun 2008, 05:11 pmI've probably asked this before, but where is the best bang for your buck with PC's? My thinking was the preamp, amp, and then maybe the DAC in that order. I usually worry less about a Squeezebox power supply item.I have a Lessloss on the pre and a nice Moon Silver Dragon on the Pass Lab and the original Iego's silver platedon the other stuff with a few Signal Cable PCs thrown in. Not sure where to apply one, but was interested in the gold version C for more body. But needing almost 3 meters for the amp attempt and only 1 to 2 meters for the pre.....^Opinions?^
Zyca,what is the overall gauge (per leg)?
I am interested in the Iego power cord for my amp and wonder if you can share an opinion on which one might best suite me. The amp is a class D Wyred4Sound and I am using an 8' BSC Violet plugged directly into the wall. With this combination I find the overall sound a bit thin and the highs to be a little piercing on vocals at times. What model in the Iego lineup would be best match up with this amp to try and tame these problems?
