Any idea on which model would drive the top end of my HT3's?
0 Members and 1 Guest are viewing this topic. Read 5134 times.
Big Red Machine
Re: Any idea on which model would drive the top end of my HT3's?
« Reply #20 on: 5 Jun 2008, 11:36 pm »
Yes, I'm not looking for db's.  I don't want to have a megabuck tube amp when I can get the punch I need from a SS and see if I admire what I might be able to achieve on the rest with tube power.
cdorval1
« Reply #21 on: 6 Jun 2008, 07:35 pm »
I've run a single U70 with my HT3s and listened for long periods.  At low to moderate levels the sound was sweet and involving.  I don't push it.  The few times I've turned it up it's clear it doesn't have the dynamics of my AVA 550exr which I usually use.  But I love swapping it out from time to time.  The sound is enticing.
To reacquaint yuourself with that "tubey" feeling, you might try hooking just the U70 up for a while.
FWIW.
Craig
avahifi
    • http://www.avahifi.com
« Reply #22 on: 7 Jun 2008, 02:03 pm »
A pair of Ultimate 70 tube amps run bridged with an OmegaStar bridge perform amazingly well driving the Salk HT3s.
Frank Van Alstine
