0 Members and 1 Guest are viewing this topic. Read 4813 times.
It's my opinion that most noise is from static electricity on the vinyl. That is why I used a damp record brush that has been misted with a spray bottle containing 1/4 99% isopropyl alcohol and 3/4 H20 (distilled). I listen to vinyl every night. Many of my LP's have zero noise.I have also used a ZeroStat Gun, however, the companies explanation of use has me puzzled abit about positive and negative static. I believe all static is negatively charged and the only way to neutralize it is to introduce it to a positive field.Wayner
Posted by: AliG you mean you use that wet record brush on the vinyl prior to each play?
Posted by: BobM Insert QuoteSo does that translate to a zap on the pull or the release of the trigger?I believe the company recommends a zap on the release of the trigger, no?Bob
...I use the simple Disk Doctor process, with a rinse of filtered water at the end, a quick pat down of the excess water with a lint free paper towel and then an air dry. I don't put anything else on my records, but I do find that paying extra attention to that last rinse made a whole lot of improvement....Enjoy,Bob
