Odyssey Stratos Mono Extremes SE's and a Candela are in the house
0 Members and 1 Guest are viewing this topic. Read 10535 times.
Cacophonix
I tried both ways, and ended up without inverting the phase. Inverting the phase, i found that the sound was diffuse, and had exaggerated bass. Try both ways, and stick to what sounds best to you.
golfugh
  • Dead Can Dance - Into the Labyrinth
Cacophonix
Thanks for the info, I'll give it a go.
golfugh
Well I tried inverted phase for a while and I agree with Cacophonix, bloated bass and almost sounded 1970's "quadrophonic".  I recently rolled in a pair of Radiotechniques and the Candela sound is incredible.  Depth, clarity, bass impact and overall soundstage much improved.  More to come...
laserboi
I too recently took ownership of a Candela paired with a Stratos Extreme SE.  I was wondering what you do in terms of shutting off the preamp.  I noticed even if I put the Candela into HT bypass mode that when I shut it off I still get an audible pop from my speakers, which makes me nervous.  I don't like the fact that I have to shut my stratos down first because of the warm up time on this amplifier.
What are you doing?
golfugh
I've never experienced any sort of pop.  I leave the Candela on most of the time.  If I'm going to be a way for a while, week or so, I'll turn off the Candela, but I leave the amps on all of the time.
I do have a transformer hum in my amps prior to the Candela tube circuits catching then its clear, about 20 seconds or so.
Edit:  Try turning down the volume on the Candela prior to turning it off, if you still have a problem.  Just a thought.
laserboi
I guess I'll leave it on unless I'm leaving for an extended period of time.  Thanks for the input  :thumb:
