0 Members and 2 Guests are viewing this topic. Read 97769 times.
In the meantime why not put up a new measurement of your 12" now that you have played with them for a good while, that would be interesting.
I agree with Graham wholeheartedly; without knowing the details, it sounds as though SuperBoy 15 might in some way be a godsend of an option. A 100db 15inch killer midband is, in my opinion, a good thing.I know Fostex has very high quality transformers for a decent price, and it seems to me that likely even better $ value might be had sourcing them from the people who do whole room installations, with remote volume controls mounted on switch plates, on walls. www.fostexinternational.com www.madisound.com A balanced design using this Green Monkey means one is now open to use tiny triode amps. At 100db, the David Berning Micro ZOTL comes to mind, a OTL design using 6SN7 which works best on battery power you could crack the walls with 3/4 watts with that thing. I am very much looking forward to hearing about the SuperBoy. I think transformers for that one, are the way forward.
