reqd : User Manual of Tektronix DMM 254
0 Members and 1 Guest are viewing this topic. Read 2921 times.
jaya000
« on: 10 May 2008, 03:28 pm »
I bought old Tektronix DMM 254 w/o user manual.
when i measure the DC resistance of speaker, it is not stable.
But when i short the multimeter cable it is showing stable reading.
Is it because the load is also inductive?
JoshK
Re: reqd : User Manual of Tektronix DMM 254
« Reply #1 on: 10 May 2008, 04:43 pm »
Sounds plausible, but I don't know for sure.  I've measured speakers with a DMM before and also had non stable readings.  The output impedance of some DMM isn't very low, so its likely that it is reacting with the load.
I'd google search for your manual.  Likely you can buy one off tektronix.
