Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
shorting inputs
shorting inputs
0 Members and 1 Guest are viewing this topic. Read 1446 times.
PatOMalley
This text is personal
shorting inputs
5 May 2008, 01:40 pm »
Jim,
Any issues with using RCA shorting plugs on the Clarinet? I can put together a set with resistors or just wire for my one unused set of inputs. Which, if either, is suggested?
hagtech
Facilitator
Re: shorting inputs
5 May 2008, 06:11 pm »
No problem shorting inputs.
jh
PatOMalley
that made a nice improvement
Reply #2 on:
5 May 2008, 10:58 pm »
Dropped the noise level some.
When turning on the preamp there was a slight soft hum. Had to get close but it was there especially with the phono section selected. Now with the RCA short plugs I flipped and did not get my usually friendly hum ...
Yellow plugs have the positive tied to negative then taped; Then both ends are heatshrunk together making like mittens that can't get lost.
Other Stuff
Hagerman Technology
hagtech
shorting inputs
