Bolder Power Supply transformer hum
0 Members and 1 Guest are viewing this topic. Read 3649 times.
Val
« on: 4 May 2008, 07:54 pm »
I have owned a fully-modded SB2 + Deluxe Power Supply for several years but up to now hadn't noticed the transformer hum because it was far away from the listening position. I now have the system installed in my bedroom and this is the only component that hums like a beehive. The transformer can't be moved because it is clamped to the bottom of the enclosure by four bolts. Some ideas other than shutting it off (I use the SB as an alarm clock) or covering the PS with a thick towel for the night? :|
Charles Calkins
Re: Bolder Power Supply transformer hum
« Reply #1 on: 4 May 2008, 08:19 pm »
What happens when you hook up the stock power supply?
                                      Cheers
                                     Charlie
Wayne1
« Reply #2 on: 4 May 2008, 08:47 pm »
Val,
Send the unit to me and let me see what I can do.
Val
« Reply #3 on: 4 May 2008, 09:08 pm »
Thanks Wayne, will do.
Charles, I don't remember what I did with the stock supply, maybe I trashed it.
Val
Val
« Reply #4 on: 9 Jun 2008, 04:18 pm »
Thanks to Wayne for the power supply Mk II mods. It is back in the system and is very quiet now.
