Anand,.....Just FYI, I just got some of the vhaudio occ airlok wire that seems to be making some quiet waves. I guess I'll see for myself soon enough.-- Jim
Grant Fidelity has now entered the market with their Reference Teflon Copper Foil capacitors...nice! Values available are 0.1uf, 0.22uf, and 0.47 uf, all at 600V DC.Best,Anand.
Yeah, I saw that. For one of the more useful value 0.22uF, for example, the Psvane costs 16% less than VCap CuTF. Is this enough in cost-savings for someone to gamble on an untested cap vs. a well-established U.S. brand? If I were the usual consumer, I would want savings more in 25-30% range to take the gamble personally Then again, manufacturing a copper foil teflon cap is not going to be cheap, even in China..
It's that copper foil that makes you cringe. Regardless of manufacturer or country, they seem to be expensive. Just one look at the price of the Russian FT-3 Teflon capacitors, immediately centers you!Anand.
Yeah, I saw that. For one of the more useful value 0.22uF, for example, the Psvane costs 16% less than VCap CuTF. Then again, manufacturing a copper foil teflon cap is not going to be cheap, even in China..
Why not? Copper foil is a commercially available product, and even if the material cost is 20x the cost of aluminum foil, it should still be no more than an extra dollar per cap. Since copper is more malleable than Al, it should be easier to roll with the teflon.
Has anyone tried Solen Teflon caps (green)? They seem to be not too expensive. I wonder how they compare to Rel and Vcaps... I use russian teflons, and, though I like their resolution, I find them to be a bit gritty in upper mids/treble, and not very smooth. I may be mistaken, but they seem to have some resonances here and there, especially in upper bass. I use values of 0.047uf and 0.1uf.
In your experience, how long burn-in time does the Mundorf Silver in Oil take for it to stabilize? Is it the same for the Supremes and Silver Gold in Oils?
Based on my own limited experience, and what others are using with happy results, it looks like the Mundorf SIOs are most sucessful in speaker crossovers, followed by power supply bypass use, and AC power conditioners. I've used them in the latter two applications with small but positive results.For signal, I find them clear sounding, but too bright, and a lack of bass weight.
