SD or SDHC?
0 Members and 1 Guest are viewing this topic. Read 1347 times.
woodsyi
SD or SDHC?
« on: 28 Apr 2008, 01:59 pm »
I got caught without an extra when my SD card filled up.  :oops: I want to get a couple of extra cards.  What size and speed would you recommend?
PeteG
Re: SD or SDHC?
« Reply #1 on: 28 Apr 2008, 02:48 pm »
When I first got my new camera I just grabbed an Extreme III SDHC 4gb card which works great and I'm very happy with it,
but I too need a backup card but a little cheaper than the one I have.
Grumpy_Git
Re: SD or SDHC?
« Reply #2 on: 28 Apr 2008, 02:50 pm »
As big and fast as you can afford!  :D
seriously it depends how you use your camera.
Do you take lots of pics in sequence? - Then bias towards speed.
Do you take studio pics in RAW/TIFF? - Then bias towards size.
Are you rich? - Then just buy a 16-32Gb extreme card of some sort.
Nick.
AliG
Re: SD or SDHC?
« Reply #3 on: 28 Apr 2008, 02:57 pm »
Do y'all know this website?? If speed is important to you, take a look.. aa
http://www.robgalbraith.com/bins/multi_page.asp?cid=6007
Choose your camera on the right hand side drop down menu..
