Audio/Video Gear and Systems
The Apple Core
Crimson
iTunes question...
iTunes question...
0 Members and 1 Guest are viewing this topic. Read 1454 times.
diofan56
iTunes question...
26 Apr 2008, 02:20 am »
Hiya!
Can anyone tell me if iTunes can duplicate a CD without compression?
Dave
flatmap
Re: iTunes question...
26 Apr 2008, 03:13 am »
Yes.
Open Preferences, go to the Advanced Tab, select the Importing tab and then choose either AIFF or WAV encoder. Those are both full resolution, uncompressed.
I think AIFF does better with the metadata if I recall right.
The Computer Audiophile
Reply #2 on:
26 Apr 2008, 04:34 am »
AIFF is much better with meta data and cover art. Both are uncompressed and provide stellar sound.
diofan56
Reply #3 on:
26 Apr 2008, 06:44 pm »
Thank you very much!!!!!
Dave
The Apple Core
Crimson
iTunes question...
