White Noise & Screen Failure
0 Members and 1 Guest are viewing this topic. Read 1445 times.
Syrah
« on: 19 Apr 2008, 10:39 pm »
Hey Gang,
I don't know what is going on with my 2 Bolder modded SB2s.
The display for one of them just quit for no apparent reason.  Short of sending it back to Wayne, any suggestions on what to try?
The second SB2 is giving me a problem that has been recurring over the years.  I try to choose a particular radio station, and then the unit pumps out loud white noise.  The noise does not go away when I hit stop, turn it off, even unplug it for some time, then plug it back in.  Any thoughts as to what causes this problem?
Many thanks!
Fraser
bpape
    • Sensible Sound Solutions
Re: White Noise & Screen Failure
« Reply #1 on: 19 Apr 2008, 10:49 pm »
Don't know about the display.
The noise is likely your trying to tune in a lower resolution station.  The Bolder mods disable/remove the crystal required to tune in the lower res stations.
Bryan
