The best sounding subs need a solid box...
0 Members and 1 Guest are viewing this topic. Read 72351 times.
Danny Richie
Re: The best sounding subs need a solid box...
« Reply #20 on: 20 May 2008, 08:26 pm »
Yeah, give me just a little bit of time and I'll have the drawings done.
AUDFILE74
« Reply #21 on: 20 May 2008, 09:52 pm »
ok,sorry for the bad timing
Danny Richie
« Reply #22 on: 21 May 2008, 01:50 am »
It wasn't a bad time for you to ask me about it. I need to get some of those drawings done. I plan to do a couple of different ones, and one with the sand filled area option. I just need more hours in the day.
AUDFILE74
« Reply #23 on: 21 May 2008, 02:50 am »
If i knew corporate america would not screw with it ,and i had a winning tax free lottery ticket, i'd love a 48hr day, :thumb:
Josh
« Reply #24 on: 24 May 2008, 11:49 pm »
Danny - Have you ever tried sand filling an LS?  Would it make much difference?
Danny Richie
« Reply #25 on: 25 May 2008, 08:26 pm »
I have not. I am sure it would make some difference but so does just lining it with No Rez. I wonder how much overkill is too much overkill? It is also important on these to keep the baffle width as narrow as possible, so it would have to be done in such a way as to not increase baffle width.
AUDFILE74
« Reply #26 on: 4 Jun 2008, 08:20 pm »
hi danny, not trying to rush you, just posting this as a reminder that you said the drawings for the design of the subwoofer box ,for the pair of 8 ohm version of the servo sub, with dual 1.6 cubic foot sealed chambers would be available and posted in about a month or so.
oh and to answer your query a dear friend of mine said that overkill is the least you can do :D :thumb:
Danny Richie
« Reply #27 on: 4 Jun 2008, 08:22 pm »
I am working on them right now.
Danny Richie
« Reply #28 on: 4 Jun 2008, 09:42 pm »
Single woofer box plans are up: http://www.gr-research.com/pdf/singleservo.pdf
Danny Richie
« Reply #29 on: 4 Jun 2008, 10:25 pm »
Plans are now up for the Sand Box: http://www.gr-research.com/pdf/sandbox.pdf
AUDFILE74
« Reply #30 on: 6 Jun 2008, 03:30 pm »
« Last Edit: 7 Jun 2008, 03:52 am by AUDFILE74 »
strider
« Reply #31 on: 6 Jun 2008, 04:01 pm »
Great! Thanks for taking the time to draw them up.
AUDFILE74
« Reply #32 on: 7 Jun 2008, 03:51 am »
i thought about it while i was at work ,and i realise i was abit selfish innot trusting danny to post the drawings for the 2 driver version. my apaologies danny . i did notice 1 thing danny, in the original subwoofer topic. you said that these drivers would be able to fit in an 11 inch cutout. but the cutout in the drawings you posted arec over 12 inches.?
WerTicus
« Reply #33 on: 7 Jun 2008, 04:29 am »
that is the face plate recess size.  if you cut a HOLE that size it would fall right through :P
afaik the cutout is exactly 11"
AUDFILE74
« Reply #34 on: 7 Jun 2008, 03:07 pm »
thanks werticus, that makes a lot more sense. i took a 2nd look and you were right. i need a vacation pretty bad :green:
AUDFILE74
« Reply #35 on: 12 Jun 2008, 12:38 pm »
HI Danny, any update on the drawings for the 2 subwwofer cabinet?
Danny Richie
« Reply #36 on: 12 Jun 2008, 02:35 pm »
I might get a chance to get back on doing drawings later today.
If you can put two and two together you can pretty much get it from this one: http://www.gr-research.com/pdf/singleservo.pdf
kyrill
« Reply #37 on: 13 Jun 2008, 11:42 am »
Hi Danny
Is the title of this post true?
so if i want to do OB from 100hz and higher
 i will have better bass ( 100hz and lower) than the OB bass with two of yr 16ohm servo drivers in their own OB?
Danny Richie
« Reply #38 on: 13 Jun 2008, 02:27 pm »
My thoughts are that if you are going to build box for the best sounding subs available then you need to make it really solid and nonresonant.
OB subs are a different animal all together and have a clean transparent quality that a boxed sub just doesn't do. The OB servo subs hit hard but don't load the room. It is clean and tight with great extension but doesn't knock anything off the walls. It truly is something special.
If you are already using an open baffle speaker then this is the bottom end you've been waiting for.
fcraven
  • Don't mess with this baritone
« Reply #39 on: 1 Aug 2008, 02:29 am »
Danny,
How did you "seal the back of the amp from the inner air space"? It seams like it would be good to isolate the inner air with a nice solid dead no-rezed wall, but then maybe that would be overkill.
Typed on my new iPhone
