Another amp option open for discussion is the Odyssey Stratos, which I'd get with upgraded cap section (120,000 uF). However, I'm pretty sure the Stratos's 10k input impedance would require something other than a passive pre... What kind of output power signal / output impedance from a DAC or CD Player would I need to adequately drive a load like the Stratos? Also, does anybody have any impression(s) of the CEC 3300 CD player linked to above?
re: liking yer passive pre, changed yer mind? - sean wasn't able to conwince ya to go active after all? well what's important is that ya enjoy the music! as most folk know, the active-vs-passive (vs none?) preamp debate is similar to toob vs solid-state, etc. i prefer active (presently! ), and feel a quality active will give all the resolution needed, w/better dynamics.
The Ridge Street MSE would be in the neighborhood of $3,500-$4000 for a 15 ft pair (at introductory prices), but look at what happened to Nrchy in Audiogon. He spent something like $3,600 on a long run of Purist Audio ICs and is a happy man...
i am sure i will find someting as good for ~$300-$400.
Quote from: doug s.i am sure i will find someting as good for ~$300-$400.In your dreams... I am spending serious money in cabling because my stereo is sounding realistic for the first time. I was very happy with the cryo'ed Tice and the Straightwire Rhapsodyy II's. that was a very good *illusion*. The Ridge Street MSE Genn II is in another level and it has outperformed very expensive stuff. Seems one would have to spend 6-7 times more money in order to get beter cables--and that would be out of my budget.
sorry francisco - this is reality.
Thanks for all the info so far, guys, but can we stay on topic, which is giving me some ideas for further research for my first "serious" 2-channel setup?I'd appreciate any links to user reviews of the CEC 3300 piece, as well as any information from anyone here who has successfully used an Odyssey Stratos with a passive pre...
...the rogue 99 magnum w/its 6sn7's - now *that* was a microphonic preamp. yust *touching* the case would emit an audible ring thru the speakers. my cary slp98-l after that, also w/6sn7's, would ring, but only when tapping the actual tubes...
Quote from: doug s.sorry francisco - this is reality.These cables are unlike anything else you have experienced...
Quote from: doug s....the rogue 99 magnum w/its 6sn7's - now *that* was a microphonic preamp. yust *touching* the case would emit an audible ring thru the speakers. my cary slp98-l after that, also w/6sn7's, would ring, but only when tapping the actual tubes...just wondering...why would anyone be tapping the case or tubes on their preamp while listening to music? i always thought that reducing or eliminating vibration in your gear is beneficial to the sound but tapping on the case or tubes to intentionally introduce vibration is something new to me.
...but, when, for example, touching the pre to switch sources, & hearing a loud noise thru the speakers...
Quote from: doug s....but, when, for example, touching the pre to switch sources, & hearing a loud noise thru the speakers...just wondering who listens to music critically while switching sources? i usually get up to switch the source and return to my chair before i continue to do anymore critical listening...
The High Fidelity piece sounds interesting. I was unable to find their website or a link to that particular piece of equipment, though. Can you please provide me with a link
