Power consumption of D200's and VAC•1.
DaveX
« on: 9 Apr 2008, 10:21 pm »
Hi Dusty, Can you tell me what the power consumption (W) is of each D200 and the VAC•1 + VHP•1, (uk voltage). I'm sure it's very small, I just need to work out all my equipment's power consumption for the power re-generator I have in mind. Thanks.
CIAudio
Re: Power consumption of D200's and VAC•1.
« Reply #1 on: 10 Apr 2008, 12:06 am »
Figure the amps are 90% efficient at max power. So 400w into 4 ohms is about 900w maximum draw for the pair of monoblocks. You'll never use that much, but it's nice to have more than you'll ever need.
The headphone amp system draws so little that it's not worth calculating,
