0 Members and 1 Guest are viewing this topic. Read 4804 times.
"-Straight class D, 250 watts/ch into 4 and 8 ohms"Is this right? 250W in both 8 Ohms and the same into 4 Ohms?
The Solar Hifi class D amp is now available for purchase! I have worked very hard to make this dream into a reality, and the sonic quality of this amp has greatly exceeded my own personal expectations. Every detail of this amp has been designed to create emotional involvement into the music. This amp lets you "relax" into the music while at the same time engaging your mind to experience every last detail of the music.It is called the "Fusion", since it merges many different technologies into one produ ...
Hi Kevin, Is the steering PS an additional $650--the one that Gina Labs designed does that come with the amp or an additional $650. and for $1900, the preamp, that is passive? the stereo version for $1500, uses one transformer? Sorry, but since I am visua -
What is the form factor for the stereo and mono amps (LxWxH, weight)?Thanks,Beez
The Steering PS uses very expensive blackgates to isolate each channel of the stereo amp. That is why it is so expensive. But it does provide the ultimate in monoblock performance from a stereo amp. It is an add-on to the introductory base price of $1599.The preamp stage is not active, since an active stage is not needed. It would only get in the way of the sound. Immersion cryo treated Dact and Elna switches, with Jena Labs Ultrawire is the best you can get for sonic purity.
Hi Kevin, Are you using two transformers, true mono blocks on one chassis, or one transformer with several windings? Also, it would be interesting more for marketing if you built one with average parts. That would show off the basic model's attributes. -
Quote from: Ray BronkHi Kevin, Are you using two transformers, true mono blocks on one chassis, or one transformer with several windings? Also, it would be interesting more for marketing if you built one with average parts. That would show off the basic model's attributes. - In the stereo amp, there is only one transformer for both models. That is how stereo amps are usually done. Dual-mono wouldn't fit in one chassis, and wouldn't save much $$$ vs. the monoblocks. It's not very practical to d ...
Kevin, I probably missed the explanation, but what is the driving force behind the tubed front-end upgrade? No disrespect intended, but is it meant to address any sonic issues that exist without tubes in the signal path?
