0 Members and 1 Guest are viewing this topic. Read 86404 times.
+6dB would be the maximum gain possible with simulated 'lossless' components. However a real choke and transformer will have winding resistance...
Increasing the R in series with the choke decreases the maximum LF boost and the effect of its value is increased due to the effective LS impedance transformation.
The primary is not used.
An equivalent LS load would be necessary having an impedance peak which matches driver characteristics to properly study the circuit.
Remember that the voltage waveforms do not tell the whole story and there is a need to observe driver current as back-EMFs are reactively generated.
I see you have captured the lag introduced by the circuit.
Hi Bruno,Good LF there, and you say a system resonance of 26~27Hz with drivers having a specified Fs of 39Hz.David's driver has a Qes of 0.23; yours 0.26; both low and thus preventing unwanted driver resonance when the driver is not loaded by cabinet air.The transformer circuit has an advantage other than simply boosting LF amplitude, which anyone can already do with EQ. It improves the quality of the bass beyond what a directly coupled amplifier can achieve, whether separately EQed or not.
But then again, I DID measure 15Hz in room with my measurements.And yet I couldn't hear (feel) this (AT ALL).(I know what a 16Hz organ note feels like).
There have been measurements related to the Ripole, and I have thought about 'W' mounting LF drivers as well, but I must stick to principles relating to pistonic wave launch. I don't want output from a cone at the inside back of any mounting structure being delayed with respect to any part of a driver cone which is closer to the cabinet front. After all, kick drums always face the audience.Cheers ......... Graham.
Quote from: Graham Maynard on 18 May 2008, 08:49 pmThere have been measurements related to the Ripole, and I have thought about 'W' mounting LF drivers as well, but I must stick to principles relating to pistonic wave launch. I don't want output from a cone at the inside back of any mounting structure being delayed with respect to any part of a driver cone which is closer to the cabinet front. After all, kick drums always face the audience.Cheers ......... Graham.I had the same thought regarding pistonic wave launch: the mounting structure of my W ripole is the front slot. The sound coming from the deepest part of the cone in the slot is delayed. On the other hand , if I would consider the opening of the slot itself as the sound source, with air moving fast in and out from the slot, then I would have an Air Motion Transformer (AMT) http://en.wikipedia.org/wiki/Air_Motion_Transformer.Bruno
