0 Members and 1 Guest are viewing this topic. Read 5081 times.
Pictures would be good. aa
Ambiance tweeters are up and running -- I got them stuck on the back of the speakers firing back. And they are really stuck with strong tapes. I was worried that they might come off at first but not any more. They are completely hidden from any viewing angle except directly behind the speakers. With my set up and room treatment, they seem to add a bit more energy in the highs with the decay lingering a tad longer. It's a subtle difference. I can actually tell a little more presence in the highs off axis more than from the sweet spot. I took pictures and I will post them after dinner. FYI, they have fine matte black finish -- not that I can see them once installed.
The "user adjustable" level control is a foam mask with which you can adjust the amount of tweeter output, or damp it out completely, by moving the mask. This saves the expense of the Lpad, any sonic degradation it introduces, and about 3" of depth on the palm-sized enclosure.
B, just posted me that the Ambiance Tweeters are "finally" shipping.Problem was (delay) he had two bad box shipments, meaning the boxes were not acceptable for the purpose.Also B's DSL line has been on the fritz for the last 10 days or so, so that is why you haven't seen him checking in much.He had to post me from his daughter's dial up system, that she had reconfigured during the "fritz part".So if you don't receive your "boxes" in the next week, post me.B, expected his DSL to be back up by today Oh and B, has also promised some pics.
Well considering that they kick in at 5000hz, I'm hoping for more than just a little sizzle from a rear channel location. I'm getting 3 for all 3 rear channel speakers and considering there's minimal sizzle info back there to begin with, I'm hoping for a fuller room presentation from them. If they act like my AV123 Extended response Tweeters on my front 3 speakers, then they won't be amounting to crap. But the ERT's kick in at 11000Hz and are extended out to 40000Hz. I'm hoping that these will present more information and will react like John Casler had mentioned in his very first post on this product. I will be finding out,,,,, Cheers,Robin
Quote from: satfrat on 17 Apr 2008, 02:28 amWell considering that they kick in at 5000hz, I'm hoping for more than just a little sizzle from a rear channel location. I'm getting 3 for all 3 rear channel speakers and considering there's minimal sizzle info back there to begin with, I'm hoping for a fuller room presentation from them. If they act like my AV123 Extended response Tweeters on my front 3 speakers, then they won't be amounting to crap. But the ERT's kick in at 11000Hz and are extended out to 40000Hz. I'm hoping that these will present more information and will react like John Casler had mentioned in his very first post on this product. I will be finding out,,,,, Cheers,RobinHi Robin,Likely the extent to which the AT's will affect your sound will depend on several factors:1) How reflective your room is2) How big your room is and how near or farfield you sit3) How good your high end hearing is4) How well the efficiency of your mains matches the AT's5) How much you damp them with the foam (if at all)6) The positioning and firing of the AT's In #6 I think some might fire them at rear or side walls, as well as at the ceiling. Additonally the greatest SPL's would be had by firing them directly at you (which of course is also an option)As such, Brian's primary design goal is to add "ambiance" and not necessarily supplement a main that might be lacking "highs", although using them in a front firing "direct" attitude might do just that, but only from 5Khz up.
Also I feel that if you use it as a rear firing device that, depending on how far the speakers are from the walls, di or bi, might offer a better "open, airy" sonic.
