0 Members and 1 Guest are viewing this topic. Read 2088 times.
Andy,I think an answer to your question might be in a practical experiment. Try to borrow a DCX2496 Behringer crossover and program it for a generic 48db/octave LR crossover. Then sum the two outputs together to create a fourth-order all-pass function. You can insert this into your playback chain (probably with headphones) and see what type of audible difference you can discern relative to the reference. The "reference" should be a direct feedthrough setup of the DCX so you can eliminate any contribution the ADC/DAC of the Behringer might contribute to the sound.If you think the result is acceptable then you have another project to build. Dave.
