Picture framing
0 Members and 1 Guest are viewing this topic. Read 2118 times.
nathanm
Picture framing
« on: 30 Mar 2008, 06:38 am »
I finally got around to finishing up one of my own picture frames. It leaves something to be desired, but overall it turned out pretty good.  I learned plenty for next time.  This sucker took an entire Saturday to make!  I rabbeted the boards, joined and painted it.  The boards were already finished on four sides.  Luckily you can't see all the mistakes at this size! :wink:
ToddSTS
Re: Picture framing
« Reply #1 on: 31 Mar 2008, 01:55 pm »
I've always wanted to be able to do that.  Did you go to a class or teach yourself?  How much wood-working talent is necessary?
Looks good, BTW.  Nice color combo.
Thanks.
Todd
nathanm
Re: Picture framing
« Reply #2 on: 31 Mar 2008, 03:58 pm »
Self-taught.  I got into doing my own framing the first time I took a print to a frame shop and was presented with the $114 bill (for a $12 print no less!) which had me reeling.
It's much easier if you start off with pre-fab moulding, but the prices are very high and I have a LOT of prints I want to frame so I thought it would be better to just get the tools and do it myself. (any excuse to buy tools, right?  :weights:) The mitre cuts are the tricky bit.  The pro framers do it with a large guillotine cutter ($$$), or you can get a framing saw and either sand or trim the edges with a tabletop guillotine cutter.  I'm still not sure the way I want to go with that, hand-sawing is a pain in the, well, hand!
Levi
Re: Picture framing
« Reply #3 on: 31 Mar 2008, 04:44 pm »
Good job!
I want to learn how to do that.  Can you show a step-by step DIY? 8)
some young guy
Re: Picture framing
« Reply #4 on: 31 Mar 2008, 05:00 pm »
Looks good. Did you cut the mat as well?
I plan to start making frames this year too. Any tips you might have would be very much appreciated  :thumb: .
Jumpin
Re: Picture framing
« Reply #5 on: 31 Mar 2008, 05:26 pm »
I have had good luck with these folks for ordering frames & mats...
http://www.framesbymail.com/
SET Man
Re: Picture framing
« Reply #6 on: 31 Mar 2008, 08:58 pm »
...I got into doing my own framing the first time I took a print to a frame shop and was presented with the $114 bill (for a $12 print no less!) which had me reeling.
Hey!
    First very nice job by the way. :D
    Yeah, I know what you mean about frame shop. Who knew it would cost that much.   :o
    Anyway, believe it or not I don't have any of my picture framed up and hang around my place. But I did a few framing jobs for my family and friends. My choice of frame usually thick matte black aluminum frame. :D For mat board I cut them myself with a mat cutter kit with straight edge.
    And of course the hard part is selecting the mat color. But than again so far I usually use white. :D
    I usually get aluminum frame locally here in NYC from Pearl Paint art store. Lately I've been interested in thick and deep wooden frame but haven't found a good place to pick some up locally yet here in NYC.
   For more options and selection I usually use this site...
http://www.lightimpressionsdirect.com/servlet/OnlineShopping
   Great stuffs there but it could get pricey. :lol:
Take care,
Buddy :thumb:
nathanm
Re: Picture framing
« Reply #7 on: 31 Mar 2008, 10:40 pm »
Here's a better image of it: (broom not included)
It's gone now though, I gave it my mom for her birthday.  It's a wee bit half-ass as I did not have any glazing on hand and there's no backing paper, but what the hey moms will cut you some slack! Heh!  The nice non-glare acrylic sheets I like give me some serious sticker shock too.  It's like 40 bucks for a 32x40 sheet.  Ugh!
I'll give a quick run down.  Not as nice as a video, but if you poke around on YouTube there are framing-related videos out there.
To cut the mat: (with equal-sized borders)
1. Measure your artwork and subtract 0.25" to allow for overlap.
2. Decide what width borders you want.
3. Double that number and add it to the artwork size, this will be the outside mat dimenson.
4. Subtract the artwork size from the mat size, this will be your window dimenson.
5. Put the matboard on a sheet of foamcore and cut both at the same time with a straight blade. Don't use cardboard; it's temptingly cheap, but too acidic it will yellow your art over time
6. Set up the mat cutter for the size border you want.
7. Draw lines on the back of the mat and double check to see that the art will fit.
8. With a backing board underneath cut the mat window with the 45º blade.
9. Tape hinge the top edge of the mat to the foamcore.
10. Attach T-hinged mounting tape to the top backside of the artwork.
11. Place artwork face up against the foamcore and carefully lower the mat into position, making sure the art is centered with no gaps showing.  When perfect, press down where the tape is.
12. Carefully turn the mat and artwork over and burnish the tape down and close it up.  You should now have a finished sandwich.  You don't want to tape anything except the top edge and you don't want to tape across the entire length of the art because it needs to be able to move with humidity and temperature changes.  If you tape it up tight it could start buckling.
13. Also cut a piece of glass or clear acrylic at the same size as the mat.
The frame:
1. Cut the moulding pieces to the size of the mat adding .25" or so for wiggle room.  Measure this from the inside rabbet, not the inside or outside edge of the moulding.
2. Check to see that it's square (heh heh!) and then V-nail and glue the corners
3. Place the glazing\matboard\art\foamcore sandwich into the back of the frame
4. Jam in glazing points all along the back to hold it down
5. Lay down double sided tape along the edges of the frame's backside
6. Stick it down to backing paper.  This helps keep out dust and insects.
7. Attach wire and hardware
8. Attach felt or rubber bumpers to the bottom backside of the frame
9. Hang on wall
10. Bob's yer uncle
Boy, that reminds me of the instructions I got with my VMPS subwoofer! :P
nathanm
Re: Picture framing
« Reply #8 on: 31 Mar 2008, 10:54 pm »
Levi
Re: Picture framing
« Reply #9 on: 31 Mar 2008, 11:18 pm »
Nathan you are awesome!
Thanks for the DIY  :thumb:
Levi
