Audio/Video Gear and Systems
Owner's Circles
Bent Audio Owners
John Chapman
Seiden switch
Seiden switch
0 Members and 1 Guest are viewing this topic. Read 2936 times.
rodneyAB
Seiden switch
12 Oct 2003, 07:33 pm »
hello John
As I see it in the photos, Tony Ho uses two mono Seiden switches in his Foreplay, What advantage does he gain over the use of the stereo Seiden switch?
thanx
Rodney
John Chapman
Facilitator
Seiden switch
12 Oct 2003, 10:46 pm »
Hello!
In Tony's (awsome!) implementation the two switches are tied together via the timing belts to the remote motor so I think the only advantage was in the circuit layout and the asthetics of his design.
If the two switches are run separately and without remote you can adjust ballance by turning just one switch and that's why I get occational requests for mono switches.
Channel to channel crosstalk is sometimes used as a reason to go with dual mono switches. This is not an issue with the physically large model 45 Seiden stereo switch we use. The channels are well separated and there is even a copper sheild plate between channels.
Many Thanks!
John Chapman
www.bentaudio.com
Owner's Circles
Bent Audio Owners
John Chapman
Seiden switch
