0 Members and 1 Guest are viewing this topic. Read 1750 times.
can you say "melos"? doug s.
Quote from: doug s. on 28 Mar 2008, 04:35 pmcan you say "melos"? doug s.So Doug S what do you have in mind?Ray
hi ray,no, you cannot have mine! what i have in mind is to keep your eyes peeled for a melos preamp. this is in reference to your also looking for adwice...doug s.
Quote from: doug s. on 28 Mar 2008, 06:29 pmhi ray,no, you cannot have mine! what i have in mind is to keep your eyes peeled for a melos preamp. this is in reference to your also looking for adwice...doug s. Hi doug,lol, oh ok. Should have said that from the beginning. Will keep looking. Any particular one to look out for?Ray
what is your budget?the top melos was the ma333r; depending on condition/refurb/mods, the price can wary from a little as ~$1k, (i only saw one at this price, a steal, imo), to as much as ~$2500. the line-stage is a two-box true dual-mono affair, w/a third box for optional fono stage. awailable either single-ended (6 outs) or balanced (3 outs). remote control, wolume/balance, except for the early ma333's. at the wery end of the run, there was the music director, which was the same pre, but w/more reliable (and slightly less transparent) alps pots in lieu of the photentiometer pots.then, there's the sha-gold & sha-gold-r, a single-box iteration of the ma333r, w/a built-in headfone amp. at its end, it was the maestro, same alps pot thing as the music director. these can run from ~$600-$1200. these are remote wolume/balance. also offer ability to run passive, but i never heard anyone who thought it was better than running active.then, there's the sha-1 which is the famed melos headfone amp w/either 1/2/3 line inputs, depending on when made. this is a simple no-frills preamp that sounds fantastic; (the sha-gold was a full-function iteration of this), & usually goes for ~$500... no remote..there are other older melos preamps awailable, i am not that familiar w/all the different iterations, but they are all excellent performers, imo...one sha-gold presently shown on agon:http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1209403021hth,doug s.Quote from: Ray Bronk on 28 Mar 2008, 06:35 pmQuote from: doug s. on 28 Mar 2008, 06:29 pmhi ray,no, you cannot have mine! what i have in mind is to keep your eyes peeled for a melos preamp. this is in reference to your also looking for adwice...doug s. Hi doug,lol, oh ok. Should have said that from the beginning. Will keep looking. Any particular one to look out for?Ray
