Dusty, voltage rating of D200 transformers.
DaveX
« on: 22 Mar 2008, 05:26 pm »
I'm seriously considering the purchase of a power re-generator. Can you tell me what the max voltage rating is for the transformers (UK model) in the D200's, is it 230V or 240V. Thanks.
        :rock:
CIAudio
    • http://www.ciaudio.com
Re: Dusty, voltage rating of D200 transformers.
« Reply #1 on: 22 Mar 2008, 05:47 pm »
The transformer is rated at 240v, but I'd use 230v if 50hz...this will make the transformers quieter.
DaveX
« Reply #2 on: 22 Mar 2008, 06:45 pm »
Thanks Dusty, I've been checking my mains voltage over the week and it varies at times from 225V to 245V. The hum is hardly an issue now but when it does show itself I noticed that the needle on my multimeter doesn't decrease/increase.
The reason I'm considering a power re-generator is because I notice my system sounds better at some times than at others, this was also the case when I owned the Cary tubed amps.
