Trouble Shooting Lite DAC 60 - Static in One Channel
0 Members and 1 Guest are viewing this topic. Read 6190 times.
markC
Re: Trouble Shooting Lite DAC 60 - Static in One Channel
« Reply #20 on: 13 Jul 2008, 03:19 pm »
Josh, I replaced the 220r I/V resistors with 127r, changed the first 220uH inductors to 470uH, changed the caps to .47uf and removed the second 220uH inductors replacing them with a jumper.
Some of the earlier boards had 390uH inductors, and if thats the case, I would leave the first one and remove the second. 390uH is close enough.
Oops, forgot to mention that I also removed the second caps.
« Last Edit: 13 Jul 2008, 04:59 pm by markC »
markC
« Reply #21 on: 13 Jul 2008, 03:26 pm »
Tom, the only surface mount devices are the chips and I wouldn't touch those either. Way to easy to mess up!
