House speaker wire recommendations?
0 Members and 1 Guest are viewing this topic. Read 1252 times.
chgolatin2
« on: 19 Mar 2008, 06:20 pm »
Getting my house re-wired for all around sound in every room including the basement, bathrooms, kitchen etc.  Wanted to get some advise on audio speaker cables, not looking to spend thousands on wires since the sound is mainly going to be for enternmaint purpose and not critical listening.
I was informed to purchasse home depot speaker wires, I believe 12 or 14g.   :scratch:  Is that a good idea or should I go with something different?
woodsyi
Les Lammers
Re: House speaker wire recommendations?
« Reply #2 on: 19 Mar 2008, 10:30 pm »
This wire is very good for speakers. Connect it per the article for best results. *I* did not care for the IC's.
http://www.6moons.com/audioreviews/whitelightning/moonshine.html
« Reply #3 on: 19 Mar 2008, 10:44 pm »
Doesn't wire that goes through walls and ceilings need to be plenum rated or jacketed or something??
ctviggen
« Reply #4 on: 20 Mar 2008, 12:20 am »
It needs to be in-wall rated, not plenum rated.
