0 Members and 1 Guest are viewing this topic. Read 8338 times.
I thought a lot of my music was mastered poorly because the dynamic range was weak, but it was actually my firmware normalizing everything. I had no volume.I thought the opamp modification might be worth it for impact. My vinyl side makes things shake, you feel people's voices... My Squeezebox (modified) I was hoping would pick up with a new power supply but that was not it (got one for free anyhow waiting on a plug). Well I switched firmware for phase, because it is the easiest solution. My dynamic range is back! The impact of everything is back! Details.... Drums and everything have so much more space around them, this switch back to 15 unmuddled everything. I can compare the sound of drums on my stereo to the drums upstairs that are real and win because the drums upstairs suck. I can not stress enough how poor the current firmware available is in comparison. I think it is meant to make you believe the Squeezebox is not an audiophile worthy device, just a music sharing device, and that you must spend $2k on a transporter, NO JOKE. I thought the firmware made minor differences, but it is more than night and day. Plus I can get ear hurting levels. Here is the beauty though, I can listen to it quieter now and get more out of it!
Quote from: Destroyer of Smiles. on 18 Mar 2008, 07:53 pmI thought a lot of my music was mastered poorly because the dynamic range was weak, but it was actually my firmware normalizing everything. I had no volume.Strange. Perhaps its really the Volume Adjustment/Replay Gain setting that's turned on? It's accessible from either the player setup or SqueezeCenter. I'm running SqueezeCenter, v.83 firmware on a Bolder mod'd SB3 and the dynamics are what they're supposed to be.
I have no idea what is going on in your system, but I am running SqueezeCenter without any issues and without and loss of sound quality.George
BTW-I use release 6.5.4 with FW83 and have no absolute phase problems. I thought that this FW version sounded best but was told this wasn't true by the same jackass that says there is no difference in sound w/ a quality linear power supply vs. the OEM switch mode POS.
How are you guys choosing to convert or not convert before the network? I am afraid I have not noticed this option?
Quote from: Destroyer of Smiles. on 24 Mar 2008, 05:54 pmHow are you guys choosing to convert or not convert before the network? I am afraid I have not noticed this option? I decode FLAC to WAV on the server side and stream WAV to the Squeezebox. Less work for the Squeezebox CPU to do which means a bit less noise. I also blank the SB3 display, no screensaver or animations and have the wireless card removed.IMO, I'd recommend streaming WAV only on a hardwired connection.
jman, you may already know this, but once the ethernet port is in use the wireless card turns itself off (according to Sean at Slimdevices/Logitech). Also, putting the display up at full brightness during play is supposed to be no worse than turning it off. But any intermediate choice is not recommended.
[..IMO, I'd recommend streaming WAV only on a hardwired connection.
I do not understand. Are your music files saved as WAV? Is there an option server side to make it do this? I do not follow. What is decoding it?
FWIW I stream WAV wirelessly (Netgear WPN824 MIMO wireless router) and have never had a dropout in 2 years. Signal strength always seems to sit at about 73%.Can't say I really A/B'd but heard no apparent difference between decoding at PC side and SB2 side.Did a quick A/B with wireless vs ethernet and heard no apparent difference either. May try this more carefully when I have some time though.
