Advantages of Alnico vs. Ferrite magnets
Flashman
  • Devialet Expert 220 Pro and Vivd Oval 1.5s
« on: 16 Mar 2008, 07:55 pm »
I wondered why an alnico magnet might have an edge on a ferrite magnet and found this on the Internet (www.tedweber.com).  Pretty interesting stuff and confirms some of the comments we have heard about the alnico advantages (better high and low frequencies, and can play louder without distortion).  There's an interesting comparison to a given magnet's circuit, with the alnico being compared to a tube amp and a ferrite to a solid state amp.  Here 'tis:
The whole 'Alnico mojo' is about smooth compression at high average levels, such as what you would have running the amp flat out. AlNiCo (Aluminum-Nickel-Cobalt) is an alloy magnet and all alloy magnets are easier to demagnetize than comparable Ceramic (Strontium Ferrite) magnets. What this means is that as the voice coil starts moving in response to the input signal, it generates a magnetic field of its own that tries to demagnetize the magnet. As its effect lowers the available magnetic field of the AlNiCo magnet, the speaker becomes less efficient, the voice coil moves less, etc. The physics of it is that the small magnets near the surface of the magnet poles (called 'domains') begin to change state, or flip directions. The result is smooth compression, the same kind of operating curve compression that occurs in a tube amplifier. The ceramic magnet, on the other hand, doesn't compress or demagnetize as easily, so the voice coil moves to its mechanical limit and won't go any farther. This is why some players say ceramics sound a little edgy at high average levels as opposed to AlNiCo. However, by properly designing the entire magnetic circuit, ceramics can be made to behave quite well for desireable guitar amp tone and dynamics. You might compare the two magnetic circuits to solid state amps versus tube amps, where the solid state amp gives it all its got then clips hard, while a tube amp compresses nice and smooth. The extension of this idea, then, is that with the AlNiCo, like the tube amp, you can seem to have a louder average volume since it gets compressed smoothly. By the way, the compressing or demagnetization that occurs with the AlNiCo is not permanent. It springs right back to its design operating point.
A voice coil is like an electric motor. The bigger the voice coil, the more wire used, the more torque or pulling power you have to move the cone. With the proper match of components, you can get more sensitivity, wider frequency response, and more power handling ability.
stevenkelby
  • Adelaide, South Australia
Re: Advantages of Alnico vs. Ferrite magnets
« Reply #1 on: 18 Mar 2008, 09:38 am »
Great info, very interesting, thanks for that!
Taterworks
« Reply #2 on: 20 Apr 2008, 11:45 pm »
So, is that why we see Alnico drivers being so highly sought-after, and not so much in the case of Neodymium magnets?
I've got a pair of 2"-exit JBL alnico compression drivers (2441 16-ohm) that I'm hanging onto, and I always wondered why Alnico magnets tend to get this type of special attention. If I'm ever fabulously wealthy enough to purchase a pair of Community VHF100 ($350, but smooth as silk), I'll likely do a three-way high-efficiency design with them.
Alwayswantmore
« Reply #3 on: 21 Apr 2008, 09:50 pm »
Interesting info. When I first read about the new drivers I did a few Google searches and discovered that Eric Clapton other musicians have historically used this type of driver for its tonal qualities. Hats off to Louis for introducing this type of driver to audiophiles / 2ch music lovers. Kent
-Richard-
« Reply #4 on: 26 Apr 2008, 05:56 pm »
Perhaps this should be a must read for certain information contained in this brief but enlightening overview of Alnico (and Ferrite) magnet history. I picked this up somewhere while surfing for information.
Don McRitchie
12-19-2004, 11:50 AM
The subject of Alnico vs ferrite magnet drivers comes up fairly regularly on our site. The following is my attempt to clarify some of the issues involved. Before I get into a discussion on the merits and disadvantages of each magnet type, it is important to separate fact from fiction. To understand how this debate began, it is necessary to know a bit about loudspeaker history. Up until the late 70’s, most high end speaker manufactures used Alnico magnets due to their greater energy/weight ratio. Starting in 1978, all major manufactures (JBL, EV, Altec, Tannoy etc.) switched to ferrite drivers. That was when the myths began.
Myth #1 – Speaker manufactures switched to ferrite as a way to lower their production costs and cheapen the quality of their drivers.
Fact – The switch to ferrite was in response to a crisis situation whereby Alnico became totally unavailable. A civil war in Zaire led to the complete embargo of the world’s only source of commercial cobalt used in Alnico. There was no choice but to switch. This is why, in less than one year, every major Alnico speaker manufacturer had switched to ferrite.
Myth #2 – Due to the lower energy/weight ratio of ferrite, drivers using this material have lower total flux and lower flux densities compared to the previous Alnico drivers.
Fact – The initial ferrite conversion had the exact same magnetic energy of Alnico drivers they replaced. For JBL, the initial conversion effort focused on bass drivers since that represented their largest consumption of magnets. They had sufficient magnet stock on hand to continue Alnico compression drivers for a number of months.
To be able to continue production of the speaker systems in their catalogs, the ferrite bass drivers had to be the exact sonic equivalents of the Alnico drivers they replaced. Otherwise, the entire systems would have to be re-engineered and there was no time to do this. To give you an example, the L300 Summit, both before and after the ferrite bass driver conversion, used the exact same Alnico tweeter, Alnico compression driver, enclosure and network. The only change was that the 136A driver had its Alnico motor replaced with a ferrite motor to become the 136H. The basket, cone and suspension remained identical. The only way this could work was if the ferrite motor had the exact same magnetic energy as the Alnico motor.
As the demand for high power drivers increased, the magnetic energy of the ferrite drivers began to exceed the former Alnico systems. As an example, the last ferrite version of the Altec 515 had a flux density of 15kgauss compared to the 14kgauss of the Alnico version. The Alnico embargo proved short lived. Alnico became available in limited quantities after a year or so, but at a much higher cost. This happened before the compression drivers were converted and it was decided to continue their production to save the costs of redesign. Therefore, Alnico HF drivers remained in production for another three or four years, until it became too cost prohibitive to continue. Around 1983, they were converted to ferrite motors as well.
Nonetheless, the costs of the ferrite replacements in constant dollars remained about the same as the Alnico drivers before the civil war broke out in Zaire. Any savings in cheaper magnetic materials were outweighed by the sheer size of the magnets and the need for a large pole piece to accommodate the external magnet topology.
Now to factual differences. There are three main advantages of Alnico over ferrite:
1) greater immunity to flux modulation
2) greater heat stability.
3) greater suitability to shielded applications
There is also one significant disadvantage – Alnico is susceptible to demagnetization due to large voice coil currents.
None of these differences are absolute. It is possible to design out all of the limitations of each material. However the issue becomes one of cost.
Ferrite designs can equal or exceed an Alnico magnet’s flux stability with the addition of a copper shorting ring around the pole piece. With the use of vented cooling and heat sinking, you can manage the heat build-up on a ferrite driver to where it stays below the threshold of non-linear response. Finally with the addition of secondary magnets, you can shield the motor of a ferrite driver to the same degree as an internal ferrite equivalent.
In the same manner, Alnico drivers can be engineered to be immune to demagnetization from overpowering. JBL has done this though the use of a series of flux stabilization rings in their new 1500AL driver. However it is extremely expensive.
All in all, the major speaker manufacturers have found it more cost effective to engineer out the limitations of ferrite drivers than to do so with Alnico drivers and hence the dominance of ferrite designs.
In conclusion, I believe the modern ferrite drivers are superior to the vintage Alnico designs. This is not because ferrite is inherently superior to Alnico. Instead, manufacturers have been able to engineer out any limitations of ferrite and apply the advantages of 25 years of technological progress in driver designs unrelated to magnets. For example, cone materials, suspension design and construction has progressed significantly since the last Alnico drivers were made.
Robh3606
07-16-2007, 05:53 AM
Here's the Scoop
Ferrite magnets do not demagnitize with time or drive. They are affected by temperature but that is reversible. They will return to normal when they return to room temperature. Ferrite is basically a lousy magnet material for speakers but it is cheap and readily available. JBL has done a ton of things within the magnetic circuit to make the material behave in a more stable manner. At 100 degrees F, a Ferrite motor will be down about 1.5 dB in level which means the midband of the woofer will be lower by that much and there will be increased output around the system resonance. The TS parameters will be completely different - as though the BL was reduced by about 18%.
Alnico magnets, by their nature are easy to demagnitize with drive. They will not change with time and their dependence on temperature is really small - maybe 1% at 100 deg.F. Alnico stability and resistance to back EMF is really good. This is why they make the best sounding magnetic structures. Unfortunatelly, given a big enough pulse of magnetic energy, they will demagnitize by up to 3 dB. The sensitivity to demagging is dependent on the specifics of the magnetic circuit and the length of the coil providing the field. Underhung woofers (LE15 and such) midranges, tweeters and compression drivers do not have sufficient back EMF fields to push the operating point of the structure below the knee. They are essentially stable regardless of input signal. The short-gap, long-coil speakers are the ones that have a problem. A 2235 can take a hit of up to 3 dB if a big enough hit of current takes place. 1.5 dB to 2 dB is more common. The effect does not get better or worse with time, it solely depends on how much current is driven through the coil. The more current, the more field. Once the field is bigger than a certain number, some amount of demagnitizing occurs. It is perminent (until externally recharged) and will only increase if a larger sustained current hit occurs.
Therefore, if you have a qualifying alnico woofer and you have played it loudly you have some damagging. You can have the unit recharged and it will be fine until you play it again. Exceed the critical level and it will start happening. If you never do, it won't ever demag. Most of these designs trace back to the 50's and 60's where 15 - 30 watt tube amps were the rule. They didn't have the current capability to hurt anything. With the advent of big solid state amps, the current levels went up and the problems started to surface.
Most of the qualifying 4" motors will loose 1 - 1.5 dB unless they are pummeled. Some of the older 3" with really short magnets, like the 2213A and 123A will typically be around 3 dB down. They go really easily. The old Decade woofers (116A and 127A) only had to see an amplifier in the room and they got really nervous. FYI, the new 1500Al used in the S9800 can take continued pulses of 5000 watts and loose no more than 1%. The test can only be done a few times before the coil is destroyed, but the magnetic assembly is totally stable.
vBulletin® v3.6.7, Copyright ©2000-2008, Jelsoft Enterprises Ltd.
Warmest Regards ~ Richard
stevenkelby
« Reply #5 on: 27 Apr 2008, 02:39 pm »
Richard, thanks for that very informative post.
I'm a member of that forum but would never have found that.
Just makes me more anxious to get my Alnico Supers!
raov1
« Reply #6 on: 29 Apr 2008, 01:52 am »
I'm not sure why AlNiCos sound better. I've heard the Phys .... they are awesome drivers. May be its the implementation of technology that makes Phys famous for what they are.
