Balanced Power Technologies Customized BP-1
0 Members and 1 Guest are viewing this topic. Read 4010 times.
John Casler
« on: 9 Oct 2003, 11:55 pm »
I am posting this is the Commercial Section since I am a BPT dealer, but it is actually a "mini-review" of a customized BP1 I ordered from Balanced Power Technologies for my system. 8)
http://www.b-p-t.com/
The BP1 I ordered was customized to actually contain a 20 Amp, Clean Power Center (CPC) and the BP1 7.5 amp balanced power Lo No transfromer section together in one box.
I also ordered the Bybee filters, Silver wiring, High Current Noise Filter and upgraded to the L-9 Litz Power Cord.
This is one exciting unit since it has the best aspects of both the CPC and the BP-1.
Four of the outlets are 20 amp current, filtered with Bybees and High Current Noise Filter.
The other 6 are balanced and can be used for any Analog or digital components I choose.
I plugged the unit in a couple weeks ago and haven't unplugged it since, so I would say it has "burned in" well enough.
Well what does it do?  How does it sound?
In a word -- REAL
It has taken my system a step closer to reality.
Diana Krall has visited my living room several times recently and the tone and texture of her voice has "never" sounded like this.  The sound and feathery crispness of  brushes on the head of the snare or the ridges of the cymbal are now all there.
The Overtones of a closely miked piano is now a stark reality of attack and reverberant decay
Soundstage height and width didn't change but why would it.  I didn't change the postition of the speakers.  But the precise blackness and detail of the soundstage is blacker and more detailed.
The 3-d front to back depth was now a layer or two thicker on recordings that supported that kind of sound.
It has shown me that my current weak link is my CD player and a new Denon 2200 should be here tomorrow.
But even now being able to hear the CDPs weaknesses, the reality that comes through is pretty astounding.
Once we are at a certain level, noise is not something in between the sounds that we sometimes call the "noise floor" or that is lessened with a great signal to noise ratio.
It seems that "noise" can masquarade as part of the signal, so when we hear the sound without the noise, we hear what was really there.
or the Pure sound.
Well this is what the BPT moves you to.  It gets you closer to the pure sound.
So I am expecting that the Denon will continue this process, since I have discovered that the Rotel, the Luxman, and the Harman Kardon CDPs all lack a few small areas to complete them.
Interestingly enough they do each bring something incredible to the sound, but not one has the whole enchillada.  But one thing they all have in common, is, with the BPT, you can now listen through to the sonic reality of their strengths, and what you do hear is the promise of the absolute goal of recreating a sonic reality.
Oh yea, it is getting close :mrgreen:
JoshK
« Reply #1 on: 10 Oct 2003, 03:17 pm »
What is the asking on said setup?
John Casler
« Reply #2 on: 10 Oct 2003, 07:39 pm »
Hi Josh,
The BP-1 lists for $699
Silver wiring upgrade is $50 list
Bybees - $200 list
High Current Noise filter $150
20 Amp upgrade (including C-7 20 amp PC) $30
Total list $1129
Special (private) Courtesy Pricing will be extended to all Audio Circle Members.
All power is routed through the Bybees and High Current Noise filter
You can select how many outlets you want to be 20Amp filtered direct and how many you want to be balanced. (you have 5 pair)
I also picked up the L-9 PC for my amp.
John Casler
Hold on to your Horses the Denon 2200 is in da house
« Reply #3 on: 10 Oct 2003, 09:34 pm »
OK, OK, Ok, Ok, Ok,
I feel like Leo in LETHAL WEAPON.  You know how he would get so excited he couldn't talk fast enough?
This Player is one exciting player.  If the 2900 is better than this (and it should be) it must be incredible.
First if you read the above, I haven't seemed to have needed any fancy, expensive CDP.  My Harman Kardon was always sounding pretty darn good (or so I thought)  IT had Burr/Brown DACs and always seemed detailed and musical.
Shoot, I have had guys come in to listen who owned $6000+ Cary CDPs who have sworn that I must have had some serious "modding" on this thing and they would remark how "tube like" it sounded.
OK, OK, Ok, Ok, Ok!
Well as I said above, I plugged things into my BPT and as it subtracted out the noise, I found that none of my three players had all the qualities I needed/wanted.
The HK sounded great in the mid/highs, but seemed a bit bass shy.  I tried my old Rotel (at one time it ranked on the top of both Sterophile "and" Absolute Sound) and it had great and luscious bass but got a bit "hard and glossy" on top when pushed to louder levels.
I also had an excellent Luxman that was similar to the Rotel, basswise, but didn't do the upper midbass slam.
While all three had sections that now sounded better (with the BP1) they all now had very noticable deficiencies.
It was like some of the "crap" that the BPT had cleaned up had also been "filling in" the sonic gaps so that it sounded OK.  Now that the BP1 was in the system, we had "problems in River City"! :x
Enter the Denon DVD 2200.  Easy set up, turned it on, opened the drawer (sounded solid) and plopped in my Reference Cut CD.
Play>>>> WOW.  My first cut is "internal organ" shaking bass.  It's sound was "well" beyond the Rotel.  What was this sound I was hearing from the left speaker?  like a high metallic tinkling, ... Holy Cra*, (not the old, I was hearing things I never heard before line) I was hearing things I hadn't previously heard.
"Crystaline" detail without harshness or brittleness, just sonic delicacy.
Then the Electric bass Solo.... Again.  Little subtle sounds that just weren't there before.
Stevie Ray Vaughan's  Tin Pan Alley.   What a cut and it always sounds unbelievable.  Was it different? YEP!  Stevies Guitar was more brilliant, but the standout sonic improvement was in the Bass lines and the drum impact.  Dry, solid, heavy drum impact.  WOW!
Next up, Dire Straits, Private investigations....  There are a few places in this cut where the Piano gets a little agressive, steely and "glary".  In fact at high volume it sounds bad.
Well the portion I'm talking about while now still "agressive", has been "sorted out" and sounds pretty darn good.  It doesn't rattle your teeth like before.
And the cuts went on and on, like this.
Diana Krall paid another visit and where her piano and voice used to make you wince at anything over 98db, she sounded loud but sweet and pure.  Her piano still had an edge on the very loud, closely miked notes, but it sounded more real than ever before.
So am I happy with this unit?  You bet, but you have to remember the road that got me here was not paved with High End CDPs.  I had mid-fi at best, but if it gets any better than this for around $600, I can't wait to hear it.
Just my experience, in my system and room, with my ears.  Your experiences may vary accordingly.
Just think if I would have never gotten that darn BP1 I could have lived (suffered) in Sonic Bliss, and never known.  My eyes and ears have been re-opened :o
So if your lookin' for a new "universal" player and don't have $1 LARGE to drop, this one is just about half that ($630 list) and if your system is pretty resolving, you'll probaly appreciate the difference.
randytsuch
« Reply #4 on: 10 Oct 2003, 10:35 pm »
Quote from: John Casler
Hi Josh,
Bybees - $200 list
Total list $1129
John,
Is the high current noise filter the CPC part of it?
BTW, I will come and visit you one of these days.
Randy
John Casler
« Reply #5 on: 10 Oct 2003, 11:42 pm »
John,
Randy
Hi Randy,
Although the CPC has a high quality polypropelene filter network on each outlet, there is an "upgrade" specialty "high current noise filter" as an option.
Just visit the site and then click on Power Cords/CPC, and then click on "upgrades". (below CPC)   http://web.valuenet.net/cjh/page12.html
Looking forward to your visit now that the Denon has arrived.  This rig is sounding pretty good right now.
Just give me a call.
Mad DOg
good stuff...
« Reply #6 on: 10 Oct 2003, 11:47 pm »
john,
good to hear the new additions are working out for you...:) looking forward to hearing your new all in one player...always said that your source wasn't up to snuff. glad you have now confirmed this! :)
we'll have to compare as a transport to my CD transport and all in one player as well. you might be in for another ear opening experience again! :D
John Casler
« Reply #7 on: 11 Oct 2003, 12:21 am »
Allow me to quote the famous Presidential Candidate we all know...
I'M ALL EARS.... Ross Perot. :wink:
