0 Members and 1 Guest are viewing this topic. Read 22955 times.
I've never measured anything. I also have almost no classical. I would imagine that yes, any recording I have, if you were able to have a dial that moved that response curve of the HT3's, F3 of 29hz-F10 of 22hz, up 10hz to 39 and 32, it would have quite an effect on the presentation. And the better the recording, the more dramatic the effect would be. I'm not basing this on those numbers because I have measured them, I'm using the speaker makers numbers and then comparing what I do or do not hear with the speakers.
I heard it at RMAF. One time we came in the room the Songtowers were playing. WONDERFUL sound, very nice. And the imagining to my ears might even be a little better than the HT3's, I didn't hear them for that long. But when Jim switched back to the HT3's it was obvious in the low end. My non audiophile wife commented on the bass right away. Fuller more complete sound. I had the Dahlquist DQ10's for many years, manufactures spec of F3 @ 37hz. I was never satisfied. But you have to pay a lot for it if you want to keep the kind of qualities the Songtower already has. For some folks it doesn't matter, for others it does. And until recently in would not have been in my budget.
Again, I would argue that there is a difference between whether one speaker can go lower than another, and whether one speaker can move more air and thus perform with more authority, power, and fullness throughout the bass range. The HT3s, with their much larger bass drivers, are simply moving more air than the STs, within the 40 hz plus range where both speakers put out sound. And that latter phenomenon could be responsible for the difference you heard, in addition to the fact that the HT3s go lower.
BTW, I hosted funkmonkey to listen to my SongTowers, and he's a sophisticated guy (not at all the audio bumpkin that some of the replies in this thread make him out to be). But I essentially asked him the same question: why the focus on 30 hz (The way I put it was: "Do you listen to a lot of pipe organ music?"). I told him that what I feel as "bass" in the music I love (electric bass and kick drum) is well above 30 hz in tone. His response was that he feels there are essential elements of stand-up acoustic bass tone that dip down to 30 hz. That didn't seem right to me, but I didn't argue the point any further.
Quote from: Boybees on 14 Mar 2008, 08:29 pmBTW, I hosted funkmonkey to listen to my SongTowers, and he's a sophisticated guy (not at all the audio bumpkin that some of the replies in this thread make him out to be). But I essentially asked him the same question: why the focus on 30 hz (The way I put it was: "Do you listen to a lot of pipe organ music?"). I told him that what I feel as "bass" in the music I love (electric bass and kick drum) is well above 30 hz in tone. His response was that he feels there are essential elements of stand-up acoustic bass tone that dip down to 30 hz. That didn't seem right to me, but I didn't argue the point any further.I agree completely with funkeymonkey on this. There is a transient at the beginning of a plucked note, whether bass fiddle or electric bass that requires response down to 20 Hz to be properly reproduced. I have a wide range system - SP Tech Timepiece 2.1s that are good down to 30 Hz plus stereo Hsu subs that take it further down to 18Hz at -3 dB, 13 Hz -6 dB. I also have the ability to shelf low frequencies with the dsp in my digital audio workstation, so I can create a high pass shelf and slide it from 20 Hz up to whatever and listen to the results. Those "pops" at the beginning of notes from any instrument that has a percussive component - and that includes bass fiddle, acoustic guitar when slapped, electric bass and kick drum - seem to need bandwidth down to 20 Hz to be properly reproduced.
There are only 3 orchestral instruments that reach below 40 Hz--Double Bassoon (25 Hz), Piano (28 Hz), and organ (20 Hz). See http://www.listenhear.co.uk/general_acoustics.htm
Quote from: BrianM on 17 Mar 2008, 01:48 pmSo we're recommending another mfr's speaker in the Salk Circle? Not exactly cool...anyway based on what I've read about both of them I'd be surprised if the Stratas image as well as the Songtowers.
I agree its in bad taste to come onto someone else's forum and recommend another companies loudspeaker.
I don't like to throw stones and I'd say most of Mark's products are good ones, but have you seen the measurements of the Strata Mini?The response curve looks pretty ragged, as I'd expect with the drivers & layout but what is most troubling is that distortion measurement. Yikes....http://www.soundstagenetwork.com/measurements/speakers/av123_strata_mini/
